4 members (TooMany2count, MNSmith, moparguy, TexasJim50), 56 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#57516 03/08/2006 2:59 AM
Apprentice
Apprentice
Hey everyone,
The 216 in my '42 3/4-ton special runs smooth and great in every way, except that if I push the gas pedal too fast, the engine sputters and coughs. It'll take as much gas as I want to give it, but only if I push the pedal down slowly and smoothly.
Is that normal for these old 216s, or is it something I can fix?
-Jon
Jon
1942 Chevy 3/4-ton Special
I don't need instructions. I have a hammer.
#57517 03/08/2006 4:04 AM
Mine does that too, but it seems to work better after it's warmed up for a while.
Which makes sense... If you supply too much gas to the carb at once, it sputters (and if you're really unlucky, stalls). But after things have warmed up a bit, the carb is hot, which assists in the vaporizing part of the process, which will lead to less sputtering.
Or, I could be full of crap. grin
Someone will be along shortly to straighten me out if my theory is wrong. smile
#57518 03/08/2006 4:17 AM
the warm up does affect that kinda behavior, but so will the vacuum advance, or even a bad accelerator pump in the carb
#57519 03/08/2006 5:05 AM
Jed Offline
Bikesmith and Brendan,
I think I'd have my carb looked at, if I were you.
My 216 doesn't exhibit that type of behaviour at all, and I'm even running on of those Rochester's that are always being trashed round here.
#57520 03/08/2006 11:40 PM
Riding in the Passing Lane
Probably the accel. pump but can be a low float level. Sometimes advancing the timeing a little can help.
1972 Chevy c10 Cheyenne Super
#57521 03/09/2006 12:21 AM
Also if your manual choke wors properly u can leave it pulled out just a scootch till the manifold gets good and warm that is if it runs right after the engine is warmed up good...Ronnie
#57522 03/09/2006 6:09 AM
Just curious, my low pressure 235 runs better cold, an way better if I leave the choke out a little even when its really warm. I say I'm curious because I just want to know, I have a full pressure 235 going in it awefully soon with a T5 so it doesn't really matter. Thanks.
Colin
#57523 03/09/2006 12:40 PM
colin on last post,,,,dirty carb,,,low float,,,power piston sticky,,main jet a little small..doc
#57524 03/10/2006 4:21 AM
Apprentice
Apprentice
Here are a couple more pieces of info that might help pin this trouble down.
First, I didn't mention before that the carb is a Rochester B. I know, I know, but that's what was in there when I got the truck smile .
Second, I recently installed Fenton headers. The problem I described at the top of this thread predates the headers, but it got worse when I put them in, which is why I'm working on it now. I've seen vacuum leak suggested, but would that cause a problem only when I push the pedal too fast and leave the engine running as smoothly as ever otherwise?
Third, in another thread I saw that headers often require a richer mixture than stock exhaust, so I tried adjusting the mix. That made the engine 90% better, but I had to adjust it 2-3 turns out before it made a difference, and now I think I'm running too rich. And it still has a bit of hesitation on acceleration. Also, I notice it mostly in second gear. It barely does it at all in first. Is that significant?
-Jon
Jon
