0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 29 Apprentice | | Apprentice Joined: Feb 2005 Posts: 29 | Dear All:
On the way to Lowes last week, a big cloud of white smoke began following me as I pulled into the parking lot. Turns out the lower oil filter hose had sprung a leak and was shooting oil onto the exhaust pipe. This turned into Sherwood's first ride on a flatbed -- the wife said it looked like he was coming home on a gurney!
Sherwood is a 1954 3100 with a 235 engine.
I searched the various parts houses and found a pair that seemed correct from Jim Carter. They arrived, and I was a bit disappointed from the start in that they're printed along the side, "For use on handheld grease guns only." Oh well.
Then I examined the tips on the replacements. The originals each had one tip with a regular, "square" tip, and the other end with a tapered tip. The tapered tips both connected to the canister. The replacements do not have the tapered tips, just square on both ends.
After some thought, I figured they would work, thinking that if it came to it, I could wrap some teflon plumber's tape around the ends.
I went to put them on this evening, and found that while the tips do fit into the engine openings, they do not fit into the cannister. They are a bit too small, enabling me to work them in to the opening without even screwing them in.
So, before I start ordering hoses from more parts houses, I have two questions for you fine folk:
1. Has anyone ever found the hoses as I'm describing my originals; and
2. Is it possible to take my old tips to a hydraulic shop and have them make new hoses for them?
Thanks in advance for your help!
Best Regards,
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I've nevr really looked for them from the parts houses, I just took my old ones to the flaps and had new ones made. You should be able to get new ones made up with the correct ends, they are still available new. BTW, the tapered end is 1/8" NPT, the other end is 1/4" double flare, just like a brake line. In fact, I used 1/4" brake line to make my oil filter lines, with 2 lengths of flaps sourced rubber oil line to allow for flex.
Bill Burmeister | | | | | Joined: Feb 2005 Posts: 29 Apprentice | | Apprentice Joined: Feb 2005 Posts: 29 | Bill:
Thanks for the information. :-)
I forgot to mention that before I gave in to calling the tow truck, I walked across the street to an Advance Auto parts store with the old hoses in hand. They weren't able to help me, saying it was a "dealer part!"
I'll check another flaps that's smaller and owner-operated.
BTW, you said you used 1/4" brake line to make your own, but included rubber lines to "allow for flex." Are you saying you mixed steel lines with rubber hoses to make your own?
Thanks again for your help.
--John
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | In a nutshell, yes. The rubber lines are hooked up to the block like normal, then are attached to 1/4" steel brake line with the proper adapters. My filter is mounted to the left inner fender, rather than to the intake, which is why I needed longer lines. Rather than having very long rubber lines flopping around, I decided to use rigid steel line that is firmly attached to the fender.
Bill Burmeister | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I went to a local tractor store and had them make me a set. They put the correct fittings on each end and worked great, and half the price of so so aftermarket sold hose sets. | | | | | Joined: Feb 2005 Posts: 29 Apprentice | | Apprentice Joined: Feb 2005 Posts: 29 | Gentlemen:
Thank you for the fine input!
Bill and Tiny: I went to your picture pages and looked at your oil line setups. Y'all have given me the information that I need, and so I will pursue fabrication of my own, rather than ordering from another parts house.
--John
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Classic Parts has a set that include all the fittings & swivels. It is complete. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Go to the local flaps that builds hydraulic hoses. That one should be rather inexpensive, and the ends will be clamped in place. We build hoses like that at my work place all the time.
Easy to do. Will fit right. | | | | | Joined: Feb 2005 Posts: 29 Apprentice | | Apprentice Joined: Feb 2005 Posts: 29 | Gentlemen: Thank you for further information on the subject.
Today, I took my dry-rotted originals to a hydraulic hose company. They're going fabricate some new ones and have them ready tomorrow.
Roy: Given that many of this company's products are supplied to large yacht owners (it's near Port Everglades), I don't know if I'm going to get away with an inexpensive part. I did tell them to go easy on me! We'll see what they decide to charge me.
Wrenchbender: If they leak, I'll look into the Classic Parts set!
--John | | | | | Joined: Feb 2005 Posts: 29 Apprentice | | Apprentice Joined: Feb 2005 Posts: 29 | Gentlemen:
I thought I'd close out the string for future reference by someone else working on the same.
I picked up the new hoses last week, and they were pretty -- the guy making them spent some time making them out of hose that I think could be found on a Pratt & Whitney jet engine! Yes, they were expensive; double what I had already paid to Jim Carter.
Started on Saturday morning, put them on and then started the truck. Everything was leak proof except for a small weeping of oil on the canister connection of the lower hose. I tighted it up a but it was still weeping. Not feeling as if I could tighten it up any more, I took it off in order to apply some teflon tape to the threads.
I then began screwing the connection back in. Everything was going well until the hose tip spun free of brass connector on the bottom of the cannister. The connector had split!
Well, the cannister would have to come off now so I could get a look at what I was dealing with. Figured since I had it off, I might as well sand blast it and paint it back to orignal colors -- blue and orange.
After taking off the brass adapter on the bottom of the cannister, I was able to screw in the lower hose that I originally got from Jim Carter, and it doesn't leak. Don't know if not using the brass connector is going matter in the long run.
So, at the end of it all, I've spent double the money, and have a completely restored external oil filtration system. One thing always leads to another on a 55-year-old vehicle!
Again, thanks to everyone for the advice.
