2 members (delky, Steelonsteel), 235 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
Apprentice
Apprentice
I just bought a 49 GMC panel and it looks mostly original but has a Chevrolet valve cover ? Engine is not too greasy but I could see no #'s I am sure I just need to know where to look. Thanks in advance!
The engine serial number is pressed into the ledge in the block that is just to the rear of where the distributor goes into the block.
Apprentice
Apprentice
I'll get out the carb clean and a brush
and figure out which 6 I have, tonight.
Thanks !
Apprentice
Apprentice
Still getting used to this site. Great info
but a little differant to the other sites I frequent. I think my engine is a 54 Chev
by what I wrote down 0176067 F547
I think I got a coup[le wrong that 7 on the end should be a Z ? Anyways it looks to be a 54. Is that a pressure oil system?
I would think so by what I've read.
Oh the head says B60 848 850
Is 848 good ? Higher compression ?
Is that engine worth hopping up for fun ?
F54Z
F = Flint MI assembly plant
54 = 1954
Z= standard 235 automobile engine
B60 848 850 - no one has posted reasonable explanation of what this code means (it is not the "848" that identifies a higher compression 56-62 head, 3836848).
1954 car engine codes
1954 truck engine codes
Locations of codes
Tim
