| | | Forums66 Topics128,081 Posts1,055,959 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 34 Apprentice | | Apprentice Joined: Sep 2009 Posts: 34 | I just bought a 49 GMC panel and it looks mostly original but has a Chevrolet valve cover ? Engine is not too greasy but I could see no #'s I am sure I just need to know where to look. Thanks in advance!
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The engine serial number is pressed into the ledge in the block that is just to the rear of where the distributor goes into the block.
| | | | | Joined: Sep 2009 Posts: 34 Apprentice | | Apprentice Joined: Sep 2009 Posts: 34 | I'll get out the carb clean and a brush and figure out which 6 I have, tonight. Thanks ! | | | | | Joined: Sep 2009 Posts: 34 Apprentice | | Apprentice Joined: Sep 2009 Posts: 34 | Still getting used to this site. Great info but a little differant to the other sites I frequent. I think my engine is a 54 Chev by what I wrote down 0176067 F547 I think I got a coup[le wrong that 7 on the end should be a Z ? Anyways it looks to be a 54. Is that a pressure oil system? I would think so by what I've read. Oh the head says B60 848 850 Is 848 good ? Higher compression ? Is that engine worth hopping up for fun ?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | F54Z F = Flint MI assembly plant 54 = 1954 Z= standard 235 automobile engine B60 848 850 - no one has posted reasonable explanation of what this code means (it is not the "848" that identifies a higher compression 56-62 head, 3836848). 1954 car engine codes1954 truck engine codes Locations of codes Tim | | |
