1 members (1955 1 Series), 135 guests, and 2 robots.
Topics128,090
Posts1,056,381
Members48,442
All,
I'm redoing my 61 Stepside and currently have an LT1 with a 4L60E tranny. The rear axle (I got from a 79 C10) has 3.07 gears. I have yet to recondition this rear axle but am ready to proceed if it is worth the effort.
Will this combination be acceptable as a daily driver and have low end power? Decent fuel economy & gutsy?
Your thoughts?
1961 Chevy C10 Stepside
On my web site
I'm not familiar with the power output of the LT1, but a quick search shows the gear ratios in the 4L60E as:
3.06 1st, 1.63 2nd, 1.00 3rd, .070 4th.
The 3.07 rear axle is an economy or freeway gear, and behind something like an M22 4 speed with a 2.20 1st gear it would be a dog, since the launch ratio in low gear would be in the neighborhood of 6.75 (1st gear x rear axle ratio). By comparison, a 2.20 1st gear in front of a 4.11 rear axle (the old hot rod standard) results in a launch ratio of roughly 9.04.
Having the 3.07 rear axle behind a 3.06 low gear would provide an impressive launch ratio of 9.39 (superior to the 2.20x4.11 setup). Combined with a .070 overdrive in 4th, the 3.07 is going to drop into the 2's, which is Bonneville gearing, and should provide fantastic gas mileage, if the engine rpm runs in the torque band.
If the engine has enough torque to power this setup, I'd think it would be nearly ideal.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Markeb,
Here are the specs on my LT1:
LT1 SPECS
Block: Cast-iron two-bolt main bearing caps
Bore: 4.0 inches
Stroke: 3.48 inches
Crankshaft: Nodular iron
Connecting rods: Powdered-metal 5.7-inch
Pistons: Hypereutectic flat-top with valve reliefs
Cylinder heads: Aluminum
Cast-iron '94-'96 B/D-body
54cc combustion chambers
170cc intake port
212-cfm airflow
Valves: 1.94-inch intake, 1.50-inch exhaust
Rocker arms: Stamped steel 1.5:1
Camshaft: Roller lifter:
202/207 degrees of duration @ 0.050 inch
0.447/0.459-inch lift (varies slightly by year and application)
Horsepower: 300 @ 5,000 rpm
Torque: 340 @ 4,000 rpm
Thanks again for taking the time to respond. My rear axle goes to the blast tent today.....
On my web site
Excellent. Looks like you should have plenty of torque for a nice all around driver and fun truck.
Markeb, thanks for the confirmation. I'm starting to feel good about my rebuild!.....
On my web site
