13 members (Otto Skorzeny, gswbbc, 68ironhead, baldeagle, Ol'55, 3B, Shardean, Cheapskate1229, panic, JW51, Jamesrsimone, Joe H, 1 invisible),
109
Mod | | | Forums66 Topics128,039 Posts1,055,473 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 54 | Hi all,
I was wondering if any of you could tell me if a starter from a 1953 suburban will work in a 1938 big bolt tow truck. both engines are original i'm just not sure what engine is in the 1953.
I am just here to learn, and to meet like minded people.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 38 tow, if we're talking Chevies, and 6 volt starters in both cases, then the answer is yes. The Chevy 216 came out in 1937, and that starter will work on 6 volt Chevy 235s, and 261s, and 6 volt GMC 228, 236, 248, 256, 270, and 302 civilian, hope that helps. | | | | | Joined: Feb 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 54 | 3B,
Thank you so much for your response. yes I was talking Chevy sorry I didn't make that clear. That will help me out quite a bit. Thank you.
