1 members (53 green 1- ton), 110 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#573145 09/10/2009 9:56 PM
Ok....Just purchased as heater box and heater distributor for my 64. This truck had nothing in regard to heater or defrost. Starting from nothing. Can someone tell me what the heater blower resistor is and what plugs into it??? I will also be purchasing a new heater control assembly for the deluxe heater.
1964 Chevy C10 Stepside
More pix on Photobucket
luann64 #573205 09/11/2009 2:01 AM
The resistpr snaps into the rear of the heat distributor sheetmetal and the main harness connects to it. This regulates the speed of the 2 lower settings by reducing power by increasing resistance. The resister gets very hot in use which is why it's mounted in the airstream. In high speed the resister is bypassed sending all power to the motor. The following link has an entry showing what it looks like:
http://www.americanclassic.com/asp/...&iyear=1964&ytype=to&exyear=
These are available everywhere, I imagine even Napa carries them. I used one for a Camaro in my 1960 GMC The only difference was the original snapped in and the Camaro used screws.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
