5 members (UtahYork, 9% grade, Wooley, 5cameo8, Shade Baby), 111 guests, and 0 robots.
Topics128,108
Posts1,056,565
Members48,448
#572817 09/09/2009 6:20 PM
I think my '62 dually has a 5.14 gear ratio and I want to go to a 4.57 gear. I don't have the truck at home right to look, should I expect to find a tag on the rear with a code for the gear ratio? Will 4.57 gears from a '63 one ton swap into the '62 housing using the '62 axles, etc?
The pumpkins should swap. I vaguely remember something about splines. The 3/4 tons used an HO52 and the 1 ton an HO72. You should find model, ratio, etc., stamped in the axle housing to the left of the pumpkin. This question comes up often, so do a search for Eaton and see what comes up.
Larry
I don't own a vehicle that isn't old enough to drink.
