0 members (),
100
Mod | | | Forums66 Topics128,080 Posts1,056,317 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | I think my '62 dually has a 5.14 gear ratio and I want to go to a 4.57 gear. I don't have the truck at home right to look, should I expect to find a tag on the rear with a code for the gear ratio? Will 4.57 gears from a '63 one ton swap into the '62 housing using the '62 axles, etc? | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The pumpkins should swap. I vaguely remember something about splines. The 3/4 tons used an HO52 and the 1 ton an HO72. You should find model, ratio, etc., stamped in the axle housing to the left of the pumpkin. This question comes up often, so do a search for Eaton and see what comes up.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
