| | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 256 | CAN ANYONE WITH AN ORIGINAL TYPE '54 BED PROVIDE ME WITH A DIMENSION?? I AM BUILDING A 1950 PU ON A BUDGET (AM NOT A PURIST) AND AS SUCH AM USING A 1983 STEPSIDE BED (SQUARE TOP)WITH MY ORIGINAL REAR FENDERS. I NEED TO KNOW WHAT THE CLEARANCE IS BETWEEN THE TOP OF THE FENDERS TO THE UNDERSIDE OF THE BED RAILS. I KNOW I SHOULD BE USING A BED WITH THE 45 DEGEREE TOP BUT THIS 83 BED WAS A STEAL. ANY HELP??? THANKS | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I can measure it tomorrow. From my picture it doesn't look like a lot. [img] http://www.angelswest.com/_borders/fckfrd.jpg[/img]
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | '54 was the first year for the flat-top bed sides. The tailgate will interchange from '54 through '87 or so. | | |
#5729 04/07/2004 10:13 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Here's a pretty good shot ... I know it ain't much because when I'm washing or waxing the truck, it's a tight squeeze in there with a rag in my hand. [img] http://www.alanhorvath.com/54chevy/chevypics/fillerdoor.jpg[/img]
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | | Anonymous Unregistered | | Anonymous Unregistered | If you are not using a 54-55 1st series bed the fender mounting holes in the bed side are not going to match the fender mounting holes. You will need to redrill some of the holes but you may be aware of this. The bed of my 54 is off at this time and I can measure the hole locations for the fenders this evening and email them to you tomorrow. If you do not need this let me know via email reply. | | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | Hey Alan, what vehicle did that filler housing come from? I don't want my filler in the bed. | | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | You may want to consider the wheel and tires you will be using. If the new bed is on the old frame with the rear wheels and tires in place slap up one fender and where it looks good mark the fender holes. Will there be running boards and the splash apron to consider?
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
