8 members (Hotrod Lincoln, carbking, tclederman, Bill Hanlon, 49choptop, Guitplayer, John L., Otto Skorzeny),
125
Mod | | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 38 Apprentice | | Apprentice Joined: Mar 2008 Posts: 38 | Vehicle: 1967 Chev Tilt Cab Viking 40. Tires: 7.50x20 Rims: The dreaded RH5. The problem: No tire shop will touch the rims, citing legal and horror stories as reason. Request: Does anyone have knowledge of a wheel to replace the RH5 10-bolt rim? The wheels are hub-centered - not wheel nut centered - having a 5.5 hole. The truck runs well but not having even half-decent rubber means it will become a driveway decoration unless substitute wheels are found. Thanks in advance for any advice/ direction. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | We have a Tech Tip for your very situation http://www.stovebolt.com/techtips/wheels/But the 10 lug hub centered with a 5.5" center hole has me confused  I'd expect 5.25" (with 7.25" bolt circle) or a lot larger. Do you have a picture of the wheel/bolt pattern, or can you double check the measurements? Grigg | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The Firestone wheels were used for 20 years or better. However, 2 piece or 3 piece motor wheel was used during the same period and they are interchangeable. One of my old 2 tons has the RH 5 wheels which I would like to replace, but haven't found anything near where I live in Texas. I have changed the dangerous kind, but I wouldn't recommend anyone to do this that didn't grow up with them. Watch things like Craigslist or post a parts wanted. I am near Vancouver at the moment and there are lots of old farm trucks in this area. I would think you could find something. I also would recommend you measure again. | | | | | Joined: Mar 2009 Posts: 169 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 169 | please post pictures of these wheels If you have Griggs attention then you are on the right track! | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | 1967 Chevy Tilt Cab Viking 40, is a pretty "Rare" truck. Lightest vesion of the truck available. Got any photos. | | | | | Joined: Mar 2008 Posts: 38 Apprentice | | Apprentice Joined: Mar 2008 Posts: 38 | Thanks for the replies. And I stand corrected; the wheels are indeed 5.25 with 7.25 bolt circle. Availability of older vehicles in this area is, at best, sparse, as is the interest in a truck of 'that age'. (If'n it don't carry 40+ tons of logs or better it ain't a truck.) Nonetheless, I shall advertise for suitable wheels. The Tech Tip is a great read and certainly clarifies many of my concerns. As for a photo, well, I have one and will attempt to post it but the dial-up in this region is akin to a native runner carrying a forked stick thus success is by no means guaranteed. I appreciate the help, fellows. | | | | | Joined: Aug 2009 Posts: 15 New Guy | | New Guy Joined: Aug 2009 Posts: 15 | Laurence,
I debated what to do with the wheels on our 55 1st series 4400. We made the decision to stay origional. I am assuming that they are the same as yours.
No tire shop is going to touch these wheels. BUT - the heavy duty on site tractor tire guys have no problem with them. They do them all the time (many tractors and machinery that are still in use hail from the time period of these wheels). Just give one in your area a call and I bet you'll have no problem getting him to come out.
FYI - we had all 6 tires (70 50 20's) installed on site for $1200.
Hope this helps. | | |
