| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 84 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 84 | I have a 1953 1/2 ton and I was thinking about swapping the torque tube for a open driveline. What's the simplest way. Can I simple swap the center carrier section from a '55 into my current torque tube rearend? Should I just get a whole '55 rearend. Are the leaf springs the same width as my '53? Is a panhard bar necessary since you lose the stabilization of the torque tube? Or are the leafspings sufficient? I am currently running a stock 3 speed but am considering the Saginaw conversion. These are just some of the questions I have. Any help would be appreciated.
Craig
1953 3100 | 1958 3/4-ton NAPCO
| | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | going on the advice of one of the senior members here, i'm swapping the open carrier section of a '55 into my '50, and then swapping an open trans. the rest of your questions would be better answered by a senior | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | that's where that chart was! i started to think i saw it in a dream. it's now in me favs list. thanks | | | | | Joined: Nov 2005 Posts: 3 New Guy | | New Guy Joined: Nov 2005 Posts: 3 | I have replaced my original trans in 1954 Chevy 1/2 ton with a 1992, Chevy S-10 five speed. I have a new speedometer to accommodate the electronic drive in the transmission. I went to Mongo's garage for some of my information. I shortened the imput shaft 3/8 inches and put the correct bearing in the engine for the imput bought at NAPA. I have a 10 inch clutch plate, stock size, with the stock pressure plate. I am having some problem with getting it in and out of gear. I read an article on Inliners about using a custom clutch plate from a 77 Vega that has a pushed out bearing to relieve such a problem for the 261 and this transmission. Do I need to put in a different plate with the Vega front bushing?
Jasper2014
