| | | Forums66 Topics128,022 Posts1,055,361 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57193 03/01/2006 6:13 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | I'm ready to hook up the fuel lines on my truck. I switched from the original Rochester carb to a Carter YF when I rebuilt the motor. I'm trying to keep the factory look, so I'll be going with metal lines. I can buy the line from the pump to carb, but it would be bent and sized to go into the front of the old Rochester carb. Can I just buy steel fuel line in bulk, and are the fittings just a single bend flare? I figure I could make the bends with a tubing bender. | | |
#57194 03/01/2006 11:16 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes buy a steel brake tube long enough. Bend it to the right angles & cut off the excess. Double flare the cut off end. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#57195 03/02/2006 12:29 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | I do the same as WBR
I buy what ever length in steel brake line (8'' - 51'')(3/16'' - 1/2''dia) and cut the end @ the carb end and use a hose to the carb. My fuel pump has a 5/16'' double flare fitting already. Remember to place a good inline filter under the truck. I believe it's better there b4 the pump and easy to change, than around the engine where if the hose leaked could cause a fire. Don't use a glass one. use a double flare fit.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#57196 03/04/2006 10:58 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I'm planning to use a remote spin on oil filter base with a filter my FLAPS says is for gasoline and fits in place of a PH8A filter. It costs cabout 14.00;I know that's a lot of money for a fuel filter,but this is a big filter.I figure to bolt it to the frame where the fuel line makes the turn to go from the tank to the fuel pump.I don't remember the part number of this filter,but when I get it,if you're interested I'll post it. just the thing for these old 'bolts with half a tank of mud. Speed | | |
#57197 03/04/2006 2:49 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Very good idea. I always put a filter between the tank & pump. But you still should have a small filter or screen near the carb. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
