3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
I bought a 2 speed WW switch a couple of years ago at a swap meet thinking I would add it when a did the wiring harness. Well the truck is rewired and everything works BUT the switch. I look on the box and it says for 60 to 63 switches with washer pump. My original switch only has one wire as the truck did not have a washer fluid pump. It does now and is run by a button on the dash but the switch I bought has 3 wires and will not run other than the fast speed.
What can one do?
EB
Riding in the Passing Lane
You have a single speed motor. You will need a 2 speed motor to get 2 speeds although you could put a resister on one of the circuits & get a slower speed. One term on the new switch is for the washer. The knob pushes in to operate it. Most wiper circuits ground through the switch so you will need a washer pump that is insulated. & make shure the switch is mounted in the metal dash.
1972 Chevy c10 Cheyenne Super
