7 members (1955 1 Series, Peggy M, mk72, Shardean, 55shaker, Uncles51, fonz8261),
59
Mod | | | Forums66 Topics128,022 Posts1,055,387 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | I bought a 2 speed WW switch a couple of years ago at a swap meet thinking I would add it when a did the wiring harness. Well the truck is rewired and everything works BUT the switch. I look on the box and it says for 60 to 63 switches with washer pump. My original switch only has one wire as the truck did not have a washer fluid pump. It does now and is run by a button on the dash but the switch I bought has 3 wires and will not run other than the fast speed. What can one do?
EB | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have a single speed motor. You will need a 2 speed motor to get 2 speeds although you could put a resister on one of the circuits & get a slower speed. One term on the new switch is for the washer. The knob pushes in to operate it. Most wiper circuits ground through the switch so you will need a washer pump that is insulated. & make shure the switch is mounted in the metal dash. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
