1 members (Tronman),
222
Mod | | | Forums66 Topics128,289 Posts1,058,583 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 99 | Hi, I am upgrading the single reservoir/cylinder master cylinder to a dual reservoir one in my 1956 GMC model 150 3/4 ton 2wd pickup. My question is this- do I have one cylinder do the front brakes and one the rear, or do I have one do front and rear diagonally opposed wheels, and the other the other two wheels?
Dave
Well, my time went so quickly, I went lickety-splitly Out to my ol' 55. As I pulled away slowly, Feelin' so holy, God knows, I was feelin' alive..... Tom Waits, Ol' 55
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | That is not a tuffy. 2 front 2 back. It would be interesting ifyou had a falure or bad adjustment if they were side and side
Was this a real question???? | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I'll agree with gazim, 2 front and 2 back. But it is a valid question, I had a Saab once that came from the factory with diagonal plumed brakes. So it isn't that unusual. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I asked this exact question way back when I was doing this. I believe most new cars are set up diagonally so at least one front wheel will be helping stop the vehicle since the rear brakes are only responsible for 10% of the stopping power. The diagonal set up seems logical to me. But in the end, I did the 2 front and 2 rear for simplicity sake. Hopefully my front brakes don't go out! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I'll agree with gazim, 2 front and 2 back. But it is a valid question, I had a Saab once that came from the factory with diagonal plumed brakes. So it isn't that unusual. VWs used the diagonal split systems too. I would imagine a front brake failure on a front/rear split would be 'interesting' in the wet!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Most cars with the diagonal split are also front wheel drive. Rear drivers and trucks still use the traditional front/rear split. Keep in mind, the port closest to the pushrod is for the front brakes, the other is the rear.
Bill Burmeister | | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | How crucial is having the port closest to the push rod going to the front? I replaced the master on my 47 1/2 ton with a dual from a 67 full size Chev car. I ran the front line from the port away from the push rod (for ease of bending the line to run along the cross member and I could use one standard length of tubing and not have to make it 2 lengths joined together). It is a drum/drum system. I know that for disc/drum cylinders the chamber for the discs is the large one. On my master, both chambers are the same size. The system seems to stop the truck well.
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Rusty...AFAIK The front brakes should be the ones that receive pressure first. That is, the first circuit to operate,bearing in mind that the fronts do most of the work. I'm not sure what would happen the other way round but I imagine in an emergency stop you wouldn't want the rears coming on too hard first. Especially on a truck which has a lighter back end anyway. Therefor, I would reckon it is pretty important you plumb the master correctly....
Anyone else have the same opinion? 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | I've searched about this on the 'net and have seen the primary and secondary chambers slated as front and rear, respectively. But some of the diagrams show that the primary is the chamber further away from the push rod, in others it's the closer one. It appears that the push rod pushes pistons in both chambers at the same time. Any more thoughts on this? Thanks.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Rusty, I think it depends on what your sytem is based on. Mine uses a Corvette style unit and bearing in mind it is reversed from the way it would be in the car. Master Power Brakes state that the front port, furthest from the pushrod is the front circuit. As you will see from my pic,I had to get 'creative' with the brake pipes. It is important they are oriented correctly. This is obviously something to do with the way the piston operates within the cylinder itself. Here's a link showing some of the more common Master cylinders. I hope this helps. Jock. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
