2 members (Wally / Montana, TooMany2count), 32 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#570036 08/31/2009 4:17 PM
Hey guys...
I've been looking for a rebuild kit for my Rochester... I'm 90% sure that it's original, but for some reason whenever I go looking for a kit I can't find one that matches up with the number on my carb.
I found this stamped on the bottom of the float bowl: 7004497-C-4. I can find matches up through 70044, but the 97 seems to throw me. I've checked NAPA, The Carb Shop, and Carb Doctor, and each time they'll have 7004468, 7004475, 7004476 (or some combo of those three) but no 7004497.
What's up?!?!
I'm planning on driving it to a show this weekend, but doubt I'll make it there unless I get this thing rebuilt.
And yes, this is for my 54' P/U with 3 on the tree, and original 235
Thanks guys
Bryan
1954 3104 235 "AD" L-6 3-on-the tree
Bryan Buser #570046 08/31/2009 4:40 PM
By accident I found a kit at Checker O'Reilly made by Holly for the Rochester for a 55 Chevy 235. I was actually looking for a rebuild kit for a Holly and when I got it home and saw what it was I rebuilt a rochester and used it instead. See if your FLAP has anybody who remembers how to read in books and they can probably find it.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
FriedGreenTmater #570119 08/31/2009 9:05 PM
I think that they make kits that serve applications from 1950 to 1972 so I don't think the numbers will matter that much. If you are looking for new jets or power piston spring then you may have a problem but usually the needed parts are there.
1951 1 Ton Completed
truckernix #570125 08/31/2009 9:26 PM
Riding in the Passing Lane
Like Nix says they should be able to supply it by application if the carb is anywhere near original. There was only about 2 kits made to cover all the model B roch. carbs. I'll e-mail my shop phone number. You can call me in the mornings & i'll help you with it. I go through K.C. K. on the way home about 1-2 o-clock in the afternoon.
Are you putting itb in the All Truck Nationals?
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. #570146 08/31/2009 10:59 PM
Brian,
They can't find carb #7004497 because it's a float bowl casting #.
That float bowl was used on different carbs.
Carb #7004468 was one of them.
To better identify your carb, what is the casting # on the throttle body?
-Tom
1950 Chevy 3100 w/ 1956 235
Oilrag #570401 09/01/2009 8:39 PM
Oilrag-
I'll have to check that tonight. Do you know specifically where on the throttle body it is?
Update: NAPA shows these carb #'s - 7002051, 7003060, 7003160, 7003864, 7003986, 7004468, 7004476, 7004495, 7005140, 7013029
Bryan
Bryan Buser #571084 09/03/2009 10:30 PM
For my application, do I need to use a gasket between the throttle body and the insulator block when re-installing my carb? The gasket that came with my kit will be blocking a small hole in the bottom flange of the carb. There is a notch on my insulator block that would allow this hole to vent into the intake manifold.
this passage is shown at the bottom of the picture as "M":
http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0651.html
I ask because, when I took the carb off, there was a gasket (same as the one that came with my rebuild kit) there that blocked this passage.
Also, my power valve check ball spring "L" looks squashed a little, but my rebuild kit didn't come with one....What to do ???
Bryan
Bryan Buser #571131 09/04/2009 12:44 AM
That hole provides the route for vacuum advance to the distributor so it needs to be open. If you want to use the gasket (opinions vary) then just punch a small hole in the gasket to accomodate it.
Ed
Forty9 #571207 09/04/2009 3:36 AM
I think you may be talking about the pump discharge check spring. If you have the little T out and it can't be used again then you need to find another one.
truckernix #571320 09/04/2009 2:13 PM
Ive got some extra T's & gaskets around I'll give you. You know how to contact me but i'm going to the Good Guys show today. I'll be at the shop Sat. George
Wrenchbender Ret. #571340 09/04/2009 3:14 PM
No...I have the T, pump discharge spring, and check ball. They looked to be in good condition.
I need a new spring for the power piston. NOT spring K, as detailed in the cut-away, I need the spring that sits between the power valve "J" and the little ball "L". Both of these are shown in the lower right corner of the cut-away diagram I attached in my previous post.
Thanks Wrenchbender, I'll give you a call Sat AM. If anyone near Kansas City has some extra springs, Rochester B parts, or whole Rochester B's that I can relieve you of, please let me know!!!
[email protected]
THANKS A TON GUYS...I don't know what I'd do without you smile
Bryan
Bryan Buser #571412 09/04/2009 6:36 PM
I find it handy to have spare Rochester Bs hanging around. That way I am never stuck for parts.
