7 members (TUTS 59, Peggy M, Gdads51, 68ironhead, tclederman, 2-Ton, wilbur53),
154
7
Mod | | | Forums66 Topics128,281 Posts1,058,476 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 50 | does anyone have a template or drawing of where they mount on the door. i want to add some factory arm rests to my doors and want to get the placement correct. thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | have you bought the armrests yet? I believe they'll come with the mounting template, the 55-59's do and they're the same as 60-66 .... of course if you've got used ones that won't help  if you check the door behind the panel near where they go, there should be captive nuts there that the rests mount to Bill | | | | | Joined: Aug 2009 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 50 | thanks. i have ordered the arm rests, just waiting for them to get here..... along with alot of other parts for the ol' girl | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | It's been a long time, but I believe to mark the holes for mine, I simply twisted in a couple of screws or bolts into the nutserts in the door, leaving them long enough to touch the panel. Then I smeared paint or grease on the head of each bolt and attached the panel. After pulling the panel back off the correct location was imprinted on the back. | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | My 64 had a factory arm rest in the driver door. I don't have the arm rest anymore but the door panel still has the holes in it. The stove screws go through the arm rest into a threaded lug pressed in the door. I can make you a template or email you the specs as to where mine sits if you need them. Just let me know..
Take Care, Good Luck and God Bless.
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Aug 2009 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 50 | if you could email me a pics and specs that would be greatly appriecated. Thanks [email protected] | | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | If your truck did not come with arm rests, you will not have the factory square nuts that are pressed into the door to hold the arm rests on. You need to go to the junk yard and get 4 of those nuts which have a press on snaps attached to them. Once you get those, as one of the other responses said like Markeb, put a couple of screws in an mark the inside panel. Note: the arm rest screws go in at about a 30 deg. angle to the door. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | The new armrests from Jim Carter have a yellow template card right in the box. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | You can order the nuts through McMasters they are called Caged Nuts, | | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | I believe the assembly manual has the dimensions in it. | | |
