Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Oswald, Otto Skorzeny, 1 invisible), 134 guests, and 4 robots.
Topics128,281
Posts1,058,485
Members48,490
#569600 08/30/2009 3:03 AM
does anyone have a template or drawing of where they mount on the door. i want to add some factory arm rests to my doors and want to get the placement correct. thanks.
have you bought the armrests yet? I believe they'll come with the mounting template, the 55-59's do and they're the same as 60-66 .... of course if you've got used ones that won't help grin if you check the door behind the panel near where they go, there should be captive nuts there that the rests mount to
thanks. i have ordered the arm rests, just waiting for them to get here..... along with alot of other parts for the ol' girl
It's been a long time, but I believe to mark the holes for mine, I simply twisted in a couple of screws or bolts into the nutserts in the door, leaving them long enough to touch the panel. Then I smeared paint or grease on the head of each bolt and attached the panel. After pulling the panel back off the correct location was imprinted on the back.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
My 64 had a factory arm rest in the driver door. I don't have the arm rest anymore but the door panel still has the holes in it. The stove screws go through the arm rest into a threaded lug pressed in the door. I can make you a template or email you the specs as to where mine sits if you need them. Just let me know..
Take Care, Good Luck and God Bless.
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
if you could email me a pics and specs that would be greatly appriecated.
[email protected]
If your truck did not come with arm rests, you will not have the factory square nuts that are pressed into the door to hold the arm rests on. You need to go to the junk yard and get 4 of those nuts which have a press on snaps attached to them. Once you get those, as one of the other responses said like Markeb, put a couple of screws in an mark the inside panel. Note: the arm rest screws go in at about a 30 deg. angle to the door.
k10 Offline
The new armrests from Jim Carter have a yellow template card right in the box.
You can order the nuts through McMasters they are called Caged Nuts,
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
I believe the assembly manual has the dimensions in it.
