0 members (),
139
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | on a '54 Chevy 3100? The reason I ask is, I have an extra box of brake shoes that the company shipped to me along with my original order by mistake. So I have an extra box of rear brake shoes and I need to know if my front brake shoes(didn't get replaced yet) are interchangeable with rear ones. What ch'all think????  | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jdl, I think the rears are only 1 3/4" wide and the fronts are 2" wide if I am remembering correctly. I know in the past I've converted the rears to 2" shoes as they use the same drum front and rear, hope that helps. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Napa shows the rears as a different number. They have a different width dimension, 1 3/4" vs 2" for the fronts. I would say measure the friction material width. If it's 2", they should be just fine for the front.
Bill Burmeister | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Thanks guys. They are different. | | |
