5 members (Gray_Ghost, UtahYork, Gdads51, Lostbuthaulinass, amtrakjoe), 63 guests, and 3 robots.
Topics128,079
Posts1,056,303
Members48,441
#570724 09/02/2009 11:52 PM
I got my new pumpkin today. The only issue is I don't understand what is stamped on the ring gear.
It ia a 72 3/4 ton center carrier. The guy guaranteed it was a 4:10. I don't understand the numbers on the ring gear it says "GM 10:41"
(then there is a bolt)
"12 (space) 1970"
What gear ratio does this equate to???
Rich
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
The ratio is 10 teeth to 41 teeth or exactly what you wanted.
Thanks Oldsub,
This was a risk as the junkyard guy I got it from did not seem well versed in these. I checked the code and it was TAJ which is a 4:10 gear 3/4 ton from a 1971.
I can't wait to get it in. I will be away this weekend so it will have to wait.
Rich
1953 3/4-Ton Chevy
More pix
RB53
This pumpkin is kind of grimey. There is some grit in the gears. Can I just flush it out with WD40 or do I need to use a different solvent or process to be sure it is thoroughly clean.
1953 3/4-Ton Chevy
More pix
RB53
Congratulations! My 410 pumpkin allows me to drive on the highway and really enjoy my truck. You should try and clean all the grime that you can out of it. I would even suggest an oil change after a few weeks driving with it.
1951 1 Ton Completed
410 pumpkin allows you to drive on the highway?
what was previously in it?
A 4.57 gear ratio Red, and those were not very highway friendly with a 216 engine. Fred is refering to driving at what is typically called highway speed, i.e., 55 mph. Since you haven't told us anything about yourself It's difficult to tell what your are driving or what your background is. The older three quarter and one ton trucks were geared made for hauling a heavy load with limited horse power so the high way speeds topped out at 40-50 mph.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
My truck originally had 5.14 gears in the rear. It now has the 4.10 set and with my 16" LT750 tires, I am turning about 2700 RPM at 60 mph. As Denny says, 50 to 55 is fine for most of my travels.
The guy I got this from said he found 4 of them in his search (they are a nation wide locator)It was not cheap ($385 with shipping) but cheaper and much easier to install than other options.
If anyone is looking for one let me know I will send you their contact info. I looked online for 2 months and was concerned that there were few of these left. These guys found 4. The first had a chipped ring gear and was deemed not salable. They sent me one of the others. I had it within 1 month of first contact.
Great service..very accessableby phone and email.
Rich
1953 3/4-Ton Chevy
More pix
RB53
Check out: www.67-72chevytrucks.com
GM 3/4-Ton Eaton HO52/72 rearends with 4.10 gears can be found for sale quite often on this web site.
Dan Michalak
1949 Chevy 3600
Divide 41 by 10 and you get 4.10 ratio .
1951 3100 Chevrolet
Price sounds about right Rich, I paid $250 for mine but I had to drive from Sandwich, IL to Rhinelander, WI., 325 miles and 6hours one way. Needless to say I was very relieved when I pulled the cover off the back and checked out the gears and bearings and found them to be in great shape and no metallic in the oil. When you figure the $150 for gas and a full 12hour day it comes out about the same or a little more than yours.
Check out the bearings and gear lash real good before you install it. If something goes to hell in that rear end you taint gonna find parts to fix it. If you find bearings your gonna pay an arm and a leg for them.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
right - 'highway speed' of another era. my '60's' cj5 had 5.10s with a saturn od and it was still a screamer at highway speed. i'm not driving it yet, but i have a '50 216 3100, and guessing that it has a 4.10. closed of course. but the 4.10? is coming out, and the open '55 3.90 is going in. i got the '55 and the straight front for $100. the 216 is also coming out and the 235 is going in
Dan,
I put a dozen posts on that site and checked daily for a while and never found one there. I think it is all in the timing.
Anyway I have heard of prices on these from $175 to $350. I think I did ok since I just had to wait for it to arrive. It looks in good shape. I cleaned it up tonight and I loosened all the bolts on the existing pumpkin and axles, drained the oil and removed the drive shaft. I hope to install the new one tomorrow and test drive.
RB53
1953 3/4-Ton Chevy
More pix
RB53
If you end up getting rid of your old one, keep the yoke. You can't buy them anywhere.
Truckernix,
I will likely keep the old one for now...just in case. But thanks for the advice.
1953 3/4-Ton Chevy
More pix
RB53
Got the pumpkin in between Friday night and Saturday morning. Took it for a test drive and man am I happy. yahoo Cruise at 55 to 60 on the highway without pushing the engine too hard.
I still don't need 1st but 3rd is now a much better gear for cruising around town.
My only question is should I have gone with 3:90s smile
1953 3/4-Ton Chevy
More pix
RB53
