6 members (wilbur53, Steelonsteel, UtahYork, Rich'sToys, Bill Hanlon, Ponchogl), 83 guests, and 0 robots.
Topics128,113
Posts1,056,616
Members48,450
#569911 08/31/2009 2:42 AM
i have a sigflare no 400 only 4 wires green,yellow,red,blue, this was in my 52 6 volt system it is now 12 volt, anyone know how this works? do i need to go to a better turn signal system thanks trying
see if this tip helps - the 4 wire setup will be for turn lights seperate from the original park and tail lights - if that's your setup, should work the same as before excpt you need a 12V flasher
Riding in the Passing Lane
Like Red say's. If you use that system you will need separate lites in the rear for the turn signals. You cannot run the brake lights through it.
1972 Chevy c10 Cheyenne Super
It was recently posted that an adapter for towing a trailer with combined lights behind a vehicle with separate lights can be used with a switch like this to eliminate the need for separate light housings.
thanks all trying
