| | | Forums66 Topics128,142 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | anybody done this before? gonna do it. just looking for the best way to do it. I was thinking about staggering the cuts and fishplating them. would it be better to make a straight cut, angled cut, or multiple angle cut to aid in structual integrity. a lot of questions I know. just always looking for the best way. thanks guys
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" Elanor Roosevelt
1966 c-10 stepside 1966 c-10 fleetside 1964 c-10 fleetside 1964 c-10 short bed 1964 c-30 flat bed 1964 c-60 dump truck 1968 Impala 1969 Nova 1971 Nova 1975 LUV 1976 C-30 1977 K-20 1966 SS El Camino
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | From an engineering perspective no need to stagger or angle cut. A straight cut is fine. Just be sure to have a welder that is certified to weld out of position do the welding. Also, fishplating isn't neccesary if the welding that is performed is full penetration and good quality. Boxing the open side of the frame in the area being spliced would add more structural integrity than the fishplating. Since your in Texas finding someone with a welding rig to do the welding should be easy enough, that is unless you are a certified welder, if so my hats off to ya.  Hope this helps. John | | | | | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | I was just concerned because it's gonna be 4x4, and looking for the strongest way. I've been accused of over engineering before. I gotta figure out how to squeeze some pictures into this fancy computer thingy and I'll take before, during, and after pics.
| | | | | Joined: Aug 2009 Posts: 12 New Guy | | New Guy Joined: Aug 2009 Posts: 12 | Not trying to tell you what to do but the best thing is to put a good weld, then grind the inside of the frame down flush. Go to a metal shop and have them bend you a piece to go inside the frame have it go as far as you can on each side of the weld. you should use 3/16 or 1/4 inch plate your frame should be 3/16, don't use anything any thinner though.You want the inner frame to be a tight fit, after you put it in do not weld it,that will cause your frame to brake. Bolt it on each side of the weld, use grade-8 bolt 1/2 in will be good for that. That will fix your frame and you want have any problems with it.I'm a welder/mechanic and this is how you cut semi-trucks and put them together, I've done alot of the.Hope everything works out good for you. | | |
