| | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57035 02/25/2006 12:38 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | I bought a dual pulley for my water pump in order to add power steering. It is for a 250 Chevy. I have a fan blade (4 blade ) that I thought was off my 250, but could have been from a 230. The bolt pattern for the blade and pulley don't match. Any insight here? | | |
#57036 02/25/2006 1:37 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I have seen water pumps w/both patterns-as well as fans & pulleys w/both patterns, I'm not sure when thewy changed, but I believe the later pattern is the larger of the 2. brian | | |
#57037 02/25/2006 5:41 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | All the aftermarket blades have a universal mounting arrangement so you may want to buy a fiberglass or aluminum blade. Just make sure it has room to flex without hitting your radiator. | | |
#57038 02/25/2006 11:04 PM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | After thinking it over, and realizing the aftermarket\universal ones are slotted, I made slots on my old fan blade to make it fit.
Thanks guys | | |
