2 members (Gray_Ghost, Joe W), 211 guests, and 2 robots.
Topics128,108
Posts1,056,231
Members48,436
#57035 02/25/2006 12:38 AM
I bought a dual pulley for my water pump in order to add power steering. It is for a 250 Chevy. I have a fan blade (4 blade ) that I thought was off my 250, but could have been from a 230. The bolt pattern for the blade and pulley don't match. Any insight here?
#57036 02/25/2006 1:37 AM
I have seen water pumps w/both patterns-as well as fans & pulleys w/both patterns, I'm not sure when thewy changed, but I believe the later pattern is the larger of the 2. brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#57037 02/25/2006 5:41 PM
All the aftermarket blades have a universal mounting arrangement so you may want to buy a fiberglass or aluminum blade. Just make sure it has room to flex without hitting your radiator.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#57038 02/25/2006 11:04 PM
After thinking it over, and realizing the aftermarket\universal ones are slotted, I made slots on my old fan blade to make it fit.
Thanks guys
