6 members (Gdads51, walter74, klhansen, Otto Skorzeny, Bill Hanlon, 78buckshot), 127 guests, and 2 robots.
Topics128,036
Posts1,055,454
Members48,422
#570213 09/01/2009 2:36 AM
I am in the process of rebuilding the 350 for my '70 GMC and am trying to find a good carb for it. I still have the stock Q-jet, but have been told that this is not a good choice. I have had others tell me that I might also want to look into a 2 barrel carb instead of a 4 barrel. This engine has been rebuilt as a torque monster with 320 horsepower, power is not an issue. I was thinking of trying to find something more along the lines of less fuel sucking, and less cost. The dude who told me to chuck the Q-jet is telling me to get a Holley 600, which is currently not in any projected budget.
"So this year, I am upgraging my policy of zero tolerance to one of SUB-zero tolerance, which is MORE than zero." -Principal Jindraike
Reedster #570217 09/01/2009 2:45 AM
Nothing wrong with the Q-Jet. When tuned properly, they're actually a very good carb. Most people who say to "chuck the Q-Jet" don't know how to work on them. While the Holley is an exellent carb, as is the Carter AFB (I've heard the Edelbrock version sucks, though), the A-Jet is the way to go for feul mileage. You'll see better mileage with that carb than even a 2 bbl. Most who say to use a 2 bbl for mileage simply don't understand how the Q-Jet works. During normal driving, you only run on the primary throttle bores, which are actually smaller than the bores on a 2bbl. This uses less feul. When you need the extra power, though, the rather large secondaries open up (about 75% throttle), and you have all the power you need.
If you want to overhaul the Rochester, do these 2 things first. 1, get a high quality overhaul kit, preferrably a Genuine Rochester kit, if you can't find one of those, Standard-Blue Strak makes a good kit as well. 2, get a shop manual that covers your carb. You may also want to check out HP Books, they have several carb manuals, including one for Rochester tuning.
Bill Burmeister
LONGBOX55 #570257 09/01/2009 4:08 AM
I have never heard Holley and better fuel milage used in the same sentence before! Rebuild the OEM Q-jet, its the best carb you can put on it.
Joe
