| | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | I need to replace the gasket for my intake in order to stop a serious leak in the 1/2 cyls.
I know I need to buy the gasket + the exhaust gasket.
What I don't know is where do I find the gasket that goes between the intake & exhaust manifold where they touch under the carb?
Also - I saw something about intake alignment rings? What are those & do I need these? Can't I just slap on the new gasket with some sealer and torque it down? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Get Fel-Pro #MS 9193 B. That's a complete intake/exhaust manifold set, and included the gasket for the heat riser. The intake/exhaust gasket is 3 peices, 2 end peices and a center peice. As far as the port rings go, they're not 100% necessary, but they do make aligning the intake to the head alot easier. Unless they've been removed from your engine, you don't ned to replace them. just re-use the originals. I personally use Permatex High Tack part #80062 for the intake gaskets.
Bill Burmeister | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Thanks Bill - I love High Tack for just about any seal.
I have not pulled the intake yet as I still want to drive the truck here & there. I plan to pull them next month when I settle in for the winter & wasn't sure what I needed to buy to get the job done. | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | I finally got around to installing the new gasket & bolts. I used a copious amount of high temp muffler gasket sealer & the truck runs like new!
I'm tickled to have all 6 cyls pulling for me now! | | |
