9 members (Otto Skorzeny, MickeyP, Biermann, jmoore, Shade Baby, TS3600, BC59, MikeStone1953, Gdads51), 114 guests, and 2 robots.
Topics128,162
Posts1,056,949
Members48,458
Somebody took the door tags off my truck when they painted it several years ago.
I need to know where the VIN is stamped in the actual body or frame metal.
Also, what GVW should the weight tag state for a 1957 3600 3/4 ton?
Is there a source for replacement plates?
I have the title, I just want to be able to travel interstate without getting hassled.
1957 Chevy 3600
At these prices I want my gas 100 octane, leaded, and my windshield washed!
The VIn is stamped on the top if the left frame rail, next to the steering box. You may also find it stamped on the frame a bit further back, under the cab. Or at least mine is stamped there.
The GVW tag is available reproduction for the 1/2 ton, I don't know for sure about 3/4 ton. The tag should say 6900#.
Bill Burmeister
vins on the frame just started in 57, some have it, some not - right near the steering box/hand brake pivot on the top flange of the frame rail, won't be found anywhere else ... GVW will be 5200 [base equipment], 5600 [bigger rear tires], or 6200 with 2 stage rear springs
I know the GVW plates are available from most vendors, haven't seen the one for the vin
Mine might be an oddity. It's stamped both next to the steering box and under the cab.
Bill Burmeister
suprised a 55 even has it, any I've seen haven't, I don't think all the plants did it faithfully until 58, a 57 I had didn't have one - also I think in the 60's they moved it back so it's under the cab, hard to see ohwell
Mine came out of the Baltimore MD plant. I have also seen a '56 3600 that was stamped on the frame. Maybe it depended on the shift as to whether it got done or not.
Bill Burmeister
I cleaned the top of the frame, can't see it.
I will try again, looking under the cab, when I have more light tomorrow.
1957 Chevy 3600
Okay! yahoo
Found it, on top of the left frame rail, just behind the front cross member.
A bit further forward than others posted, but it is there, and does match my title.
1957 Chevy 3600
1960 thru 66 trucks have the vin stamped on the top of frame rail driver side four inches in front of the engine mount bracket. 55 thru 59 have the vin driver side top of frame rail directly above the axle. Never seen one that didnt have one. OldWolf
