Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Guitplayer, Hush), 106 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
#570013 08/31/2009 2:33 PM
Hey folks, I got a question I'd bet could be answered by the general knowledge around here pretty quickly, couldn't turn up anything researching the archives.
I just noticed a knocking/popping sound the seems to be coming from the steering linkage around the front passenger side of my '64 1/2 ton. Weird thing is, the popping seems pretty random and happens when I'm going straight, not really even touching the steering.
Does this sound symptomatic of a grease-poor bearing? Is there anything else you think I should consider? I greased these all up maybe a year ago but now I'm second-guessing whether the zerks were clean enough, if it isn't just time for more grease, etc.
As always, your input is greatly valued, thanks for your time...
Bluto #570054 08/31/2009 5:56 PM
My interest is in the 50's vehicles, so I am not that familiar with the 60's. However, if you have rubber bushings (dry bolt bushings) in your suspension, they will pop if the bolt is rusted in the bushing.
The problem is a dry balljoint. You may on the right track with the grease fittings not allowing the grease in. try installing new fitings then re-grease them. You might also consider shooting some Blaster or other penetrant oil in to loosen things up a bit. if the noise persists, it's time for new balljoints.
Bill Burmeister
second the ball joint - I had this problem in a "NEW" Chrysler product I bought.
They pop when they flex while turning or hitting bumps. You may notice some wander too if they are warn. But if not warn and only dry it might not be too late.
For my money - I'd just replace them. They are cheap & if you've ever had one fail at speed you'd never forget it!
1958 Chevy Apache 3200
bone stock 235
53k miles
3 on the tree
