| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 57 | Well, when I last wrote, the carb on the 61 C20 was driving me crazy. All the troubleshooting here plus talking to Tom Langdon narrowed it down to a clogged jet. Instead of tearing that down, I punted and switched to the Holley weber. Now it's running great. But..we went with an electric fuel pump from Napa, and it hammers like a machine gun for up to a minute when I re-start it hot. I'm thinking it's pulling for fuel and getting an air bubble or something. What say you Stovebolters? | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The hammering is not going to go away. The duration of the hammering will depend how long it takes to fill the fuel bowl and come up to pressure. Mount the fuel pump as far away as possible, and use rubber isolation mounts. Then you could go back to mechanical and problem solved.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
