| | | Forums66 Topics128,043 Posts1,055,605 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | I have a 1966 with a 250 and I would like to put an aluminum valve cover on it. I can't find any that have the holes for the pvc valve and the hole for the hose that goes to the air filter has anyone bought an aluminum valve cover for a 6 cyl. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i have used a couple. i had a hole for the pcv valve but no baffle, so this coused me some headaches. i had to make a baffle since my intake was getting some oil in it. i don't think the large hose from side of valve cover to bottom of filter is that important. it can prob be omitted if you go to a breather without the hole in the bottom. i doubt you will be abe to find one of those. both mine were used alum valve covers and had the hole for pcv valve. i'm sure you could drill a hole and mill off the fins if need be. good luck to you. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | you might have more responses in the engine or driveline section if you want to give it a shot. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | If you get a cover without a baffle for the breather hole,you can buy a breather grommet that has one built in. I use 'em on my 350. Speed | | |
