2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#56921 02/23/2006 3:34 AM
I am probably opening up a can of worms with this question, but here goes...
I have the opportunity to buy two different setups. Which would you recommend or should I just skip both. They would be going on my 1954 3600.
#1 - Offy intake for 216 or 235 chevy engine, new never used includes 2 carter-weber carburetors new never used, also includes linkage. From Stovebolt Engine Co. Everything is new, unused. $300.
#2 - Used Offey intake in great condition. It has no cracks, breaks, or repairs, and all of the threads are clean. The 3 Holley II two barrel carburetors are from 1979-80 Ford Pinto and are brand new and also include new cast aluminum carb base adapters. $450
Also, is it difficult to convert from a manual to auto choke?
Thanks for your input!
Today is the best day of my life!!!
#56922 02/23/2006 3:55 AM
I'd choose #1. Unless you're cranking out well over 200 hp the duals will be a far better match. Also, you won't have to cut the firewall so the 3rd carb will fit.
Fred
52 3600
69 C-10
#56923 02/23/2006 10:42 AM
If the Holley 2 barrels are the ones I think they are,they'd be a bag o' snakes to make run on a six.
I like 3 carbs w/progressive linkage better than 2 carbs,but in this case the 2 carb gets the nod.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#56924 02/23/2006 2:26 PM
Carburetion specialist
Due to the design, Carter-Weber (the old Carter BBS) carbs are extremely difficult to modify. Also, if you should use these, make sure you have TWO throttle return springs on the unit, and check them daily.
Jon.
The Carburetor Shop
