1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 86 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 86 | I'm getting yellow pine for the bed of the truck today, 2x12s, 12 foot long. The cross sills on the bed are 3/16 thick. I figure 4 rows of fasteners with two per board at each cross sill. Flat-head plow bolts would be one option. Recessed pan head screws with washers would be another. If I routed the top of one board and the bottom of the next and overlap I could get by with one fastener per board per cross sill. That would also allow for expansion/contraction without having a gap, just a recess in the surface. This bed will probably be painted black. (If it were pretty I would be hesitant to use it!). What would you guys recommend? New pics in Webshots: http://community.webshots.com/user/ScottinWV
| | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | I'd look at good old fashioned carriage bolts. Use a forstner or Spade bit to countersink the hole before drilling the bolt hole. I like the idea of routing the edges, maybe a tounge & groove for the overlap to keep warpage down if you only use one bolt per point. As for finish, maybe look at a deck stain to protect the wood? If you paint it too dark, any scratches/abuse will show up as bright white scars. just a thought anyway. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | In my experience the correct board in DSYP is a 2x6, much easier to work with and far less suseptable to splitting. The only time I've seen wider boards are the larch laminates or tropical subspecies like apitong., etc. and they are usually 5/4 thick. Self drilling 1/4" screws are best for securing floors. | | | | | Joined: Aug 2004 Posts: 86 'Bolter | | 'Bolter Joined: Aug 2004 Posts: 86 | I'm fixin to put the deck in my '59 viking 60. I'm going to use 2x6 DSYP T&G. As far as finish is concerned who votes for deck sealer/stain, varnish, linseed oil, paint or something else?
Matt
"Brunhilde II" '59 Viking 60 To paraphrase Ben Franklin: "Big Bolts are proof that God loves us and wants us to be happy"
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | We used to refloor trailers. Our dry vans now all have aluminum floors. We always used screws so that it was a one man job http://www.imperialinc.com/items.asp?item=0692780 They are available at any semi trailer dealer. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | If your not useing T&G watch the end grain of your lumber and get it all turned the same way. I prefer to turn the grain so the board cups up in the middle so it will shed water. | | |
