| | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | Hi all, I am looking at buying someone elses project that they have run out of gas on. A 53 fivewindow. The truck was painted recently, dark maroon, and the paint seems to chip easy when hard contact is made, not enough to dent the metal, but enough to cause a chip in the paint. Could this be too much hardener in the paint or a bad seal job. The paint looks great, no runs or visible flaws. I don't know anything about paint but if it is a bad seal would that make it hard to paint over the truck again. Would it have to be taken back down to metal?
If you didn’t skin a knuckle while you were working on your truck, you weren’t working hard enough! 53 5window 1/2 ton54 3window 1/2 ton
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | When it chips is it down to bare metal? Could be the primer. Is there filler where it chips ? Mabe You could take it to a body shop and ask them what they think.
Pete | | | | | Joined: Jul 2009 Posts: 11 New Guy | | New Guy Joined: Jul 2009 Posts: 11 | The biggest question is what is left under the paint? is it chipping in specific areas? or all over? If it is mainly on edges thats usualy poor prep work, ie. neglecting to detail sand the edges..as the old rule goes" the harder it is to sand the more important it is to sand it!" as that is ALWAYS where it will chip or peel! If it is chipping after contact in the center of panels then that is poor adhesion; possibly from poor prep or wrong combinations used in reducers, hardeners or incorrect application of the paint or undercoats. I just got thru helping one of our mechanics redo his truck with the same problem, in that case it had too much paint on it ( single stage black plus clear )
| | | | | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | It appears to be a primer under the chips. and there are only a couple.
| | | | | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | There is only one on the top center of a fender, one near the tailgate where he hit it with the tailgate on installation, and one where he installed the grill. It appears to have primer underneath, not bear metal.
Thank you, Dan
