6 members (klhansen, GRNHydra, Mike Roache, Maybellene, 6inarow, 1 invisible), 138 guests, and 2 robots.
Topics128,035
Posts1,055,552
Members48,425
#568780 08/27/2009 3:30 AM
hey guys, i was wondering how accurate is your fuel gauge and how much does it bounce around? I just put a new sending unit in and filled up the tank(behind the seat). The gauge is at 5/8ish and bounces around a bit. the new sending unit had 90omhs stamped on it.
second question, on my dash, there is what looks like two warning lights. one above the ignition switch the other above the wiper switch. they do not light up. what do they do?
truck is a 65 chev c20 with gauges in the cluster.....
thanks.
trevota #568786 08/27/2009 3:48 AM
First off, that is the wrong sending unit for the stock fuel guage. The stock guage requires a 30 ohm sending unit. Now, as to the bouncing, that is pretty typical. Some are worse than others, but any truck that is still using the original fuel tank will slosh around pretty good. My '71 bounces pretty good. As to accuracy, it varies depending on the condition of the guage and the sending unit. My '71 is pretty accurate while my '63 C20 is off by about 1/4 tank.
As to the warning lights, I am not 100% sure on the '65, but I know that the '63's have a similar red lense setup and on those one is for an overspeed indicator and another is for a tandem lock. You have to remember that the guage clusters in the pickups and big trucks were the same just some stuff left off on the pickups, like the tandem lock indicators. I am assuming that is the case on your '65, anyway.
1963 Chevy C20 Longbed Stepside
1978 Chevy K30 Custom Deluxe
Bears63 #568838 08/27/2009 6:57 AM
I've owned a few 65s and the gas gauge needle on all bounced pretty good.
I'm not sure exactly which lights on the dash you're referring to though.
1947 Chevy 6400 Wrecker
Old Stovebolts don't leak oil
They just mark their territory
more than likely the h/beam indicator light and the amp meter light
ron
padresag #569013 08/28/2009 12:05 AM
Bear is correct about the indicator lights...hold a flashlight behind the dash and they will light up.
62 mark #569084 08/28/2009 3:06 AM
thanks guys. Im confused. today i drove the truck to work and the fuel gauge stayed at full. which is right as i filled it up last night. On the drive home, it was at about 3/4's and would go to full when i made left turns and to 1/2 when i made right turns. **edit** I live 10km from work, or a 10min drive.
I will call the parts store and ask about a 30ohm sender.
Thanks again
trevota #569115 08/28/2009 4:41 AM
I think that the 90 ohm came in, in 66; prior to that they were 30 ohm. if you can't get a 30 ohm ter are a few fellows around that can modify yours to 30 ohms
ron
padresag #570448 09/01/2009 11:05 PM
yup you guys were right, one says tandem lock the other says overspeed.
