7 members (Cletus1950, Bill Hanlon, papas52, dgrinnan, frogfarmer, Youngin' Tut 59, 2-Ton),
111
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,176 Posts1,057,058 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 37 Apprentice | | Apprentice Joined: Jun 2008 Posts: 37 | I was installing new fuel hoses and when I cut the rubber hose from the tank to steel line that runs to the fuel pump nothing at all came out.
I tried blowing air back into the tank, but nothing happended...
Do these "behind the seat" fuel tanks have a 1-way valve, or is it probably plugged up with gunk?
| | | | | Joined: Nov 1995 Posts: 5,738 24601 | | 24601 Joined: Nov 1995 Posts: 5,738 | Dan, Was the truck running before you cut the hose? Are you sure there is gas in the tank or line? If this was a non running truck that's been sitting awhile, it's either dry empty or plugged with gunk -- probably both.
I have a '65, and I helped hamiatjax with his '62 and I didn't see any kind of valve on either one. And even if it had a one way valve, it would certainly allow fuel to run out from the tank (assuming there was any fuel in the tank to begin with).
You might also try asking this question in the 60-66 Forum.
Good luck, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2008 Posts: 86 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 86 | I would guess gunk. When I had to cut the line on my 64, it completely drained the tank. Luckily there were only a couple gallons in it. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Guys, Assuming a siphon was established,if it wasn,t plugged up,any liquid in the tank would flow out,if it wasn,t dry. Keep in mind here that 55 and Newer,all the way thru 72, had senders AND Pickup Tubes that came out of the TOP of the tank. Last Gravity Flow to My knowledge on any G.M. truck was 55 First Series. Regards,Steve Sr. | | | | | Joined: Mar 2009 Posts: 169 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 169 | that suckers plugged at the outlet.blow some air in there and rinse out the tank usually there in good shape cause there in the cab had this happen lots and have still used the tank! | | |
