3 members (TUTS 59, thekid1950, Peggy M), 40 guests, and 8 robots.
Topics128,012
Posts1,055,320
Members48,419
#56799 02/21/2006 2:14 AM
Do all s-10 T5's have the same spline count? I have been reading through all the threads and tech tips on this and lots of great info on which clutch to use, but it is only relavant if the spline count is the same on all of them.
Colin
#56800 02/21/2006 3:21 AM
Every one I've ever seen has been the same.
Daily Driver 63 C-10 LWB Fleetside
#56801 02/21/2006 5:07 AM
Thanks Tex! Always there to help!
So s-10 splines are 14 and camaro 26?
Thanks!
Colin
#56802 02/22/2006 1:32 AM
My T5 housing is an S~10 w/ all camaro guts, using a 26 spline shaft. BUT, I had a transmission shop make it w/ the Camaro gutz in the S~10 housing. Normally the S~10's are 14 splines, as mentioned above.
Jim & Caroline
#56803 02/22/2006 5:21 PM
The S-10 T5's I've seen have all been 14 unless they were modified in some way like carolines truck says in previous post.
