7 members (FAST55, Hanks custodian, mick53, baldeagle, 50Chevy3100, Donf, TUTS 59),
71
Mod | | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56799 02/21/2006 2:14 AM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Do all s-10 T5's have the same spline count? I have been reading through all the threads and tech tips on this and lots of great info on which clutch to use, but it is only relavant if the spline count is the same on all of them. Thanks Colin | | |
#56800 02/21/2006 3:21 AM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Every one I've ever seen has been the same. | | |
#56801 02/21/2006 5:07 AM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Thanks Tex! Always there to help! So s-10 splines are 14 and camaro 26? Thanks! Colin | | |
#56802 02/22/2006 1:32 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | My T5 housing is an S~10 w/ all camaro guts, using a 26 spline shaft. BUT, I had a transmission shop make it w/ the Camaro gutz in the S~10 housing. Normally the S~10's are 14 splines, as mentioned above.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#56803 02/22/2006 5:21 PM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | The S-10 T5's I've seen have all been 14 unless they were modified in some way like carolines truck says in previous post. | | |
