0 members (), 102 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#567357 08/21/2009 11:07 PM
I`m going to look a GMC 1 ton pickup tomorrow. Supposedly barn fresh and kept. All I know from word of mouth about it is it has bug eye headlites so I`m assuming its 1941-43 ish.
How do I know if it has insert bearings or babbitted? I`m guessing that it would be a 228, 236, or 248 engine. Any advice here would sure help me out. Dont be bashfull. Thanks, John
Hey John, welcome to the bolt.I do believe they are insert bearings. The chevy engines were babbited. The engine ID is stamped on a flat pad just behind the distributor. The first 3 didgits of that number is the engine size..
sound like you have a 41-46 truck.
I have a 45 GMC with a 248 engine.
Good luck with it!
Thanks Jeffl. I have had an aversion to babbitted engines since I worked on a 36 flathead Ford some 35 years ago. Maybe if it was a babbited GM product I wouldnt have this "problem".
I`ll try to post a photo and the ID #`s if all works out. Hopefully it wont be be a wild goose chase.
So did GM ever have babbitted rods or was that just limited to Chevy? If so when was the switch made?
Im not sure on the rods. But I do know the GMC's back then, even though they shared the same cabs, they were a lot different than a chevy. they had their own engine, which was a Pontiac design,& the frame on GMC was heavier than a chevy.
Go to the Links page of this site and check out Old GMC Trucks .com. there is a lot ofinfo on the GMC's there.
John, as mentioned, the GMC engine will have the engine size dictated by the first three numbers on the pad behind the distributor. If its a Chevy engine in a GMC, youll have to go by the block casting numbers down by the fuel pump. Chevy switched to the inserts after 1953. GMC had inserts from at least 1941, which is where my knowledge of them stops.
Good luck, Jeff
My 1953 Chevrolet
1947.1 Gallery
If its original, it will have a 228 with precision bearings. They built them from 1939 through 1953. I'm not sure what you mean by bug eyed. If its 1938 or older, it probably had a Pontiac engine.
Looked at both trucks today 1939-1940ish. 228 engines. Both had been bondoed up over rust. With lots of pinholes that looked like stars when you looked up from the inside of the wheelwells. One cab wasnt to bad the other had a cab mount rotted away. Tags said General Motors truck manufactured by Yellow truck and Motor co.
I guess I`m not that interested in either one. Would rather spend more and find one in better shape. Owners looking for $4500 each. Quite a bit high by my estimate
Sounds like one too many zeros on the price.
