| | | Forums66 Topics128,052 Posts1,055,719 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | 54 1/2 ton--- Any recommendations on what to paint the running boards with in black? the truck will be juniper green with some cream accents. and will be a driver not show. not sure of the gloss level or lack of. I've searched the galleries for every picture I can find of 54's Wish I knew what an all original truck was supposed to look like in regards to color schemes. for instance painted grills, bumpers, running boards etc. any tips are appreciated. I realize that these restorations are a blank canvas to do with what we want. Just looking for some direction. thanks | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | They were painted Gloss black when new. But I think a Satin Black would look good also. | | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | I sprayed my '49 with several coats of POR-15 Chassis Coat Black. I'm happy with the look and the durability. It gives a tough, semi-gloss black finish. | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I use a medium gloss black bed liner coating on my running boards...looks good and you don't have to worry about chips and scratches. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Do-It-Youself bedliner works well, too. I did the steps on my '55, both on the bed and in the cab, with the Dupli-Color bedliner roll on kit. Looks good and is holding up very well.
Bill Burmeister | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I used the bed liner paint as well. Looks great and is durable.
