| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 39 'Bolter | | 'Bolter Joined: May 2005 Posts: 39 | Today I replaced the tail lights on my '54 Chevy 3100. The brake lights come on when I apply the brake. The turn signals and four-ways work like they should. The problems begin when I turn the headlamps on. With the headlamps on the brake lights do not work nor do the turn signals & four ways.
I thought about replacing the flasher, but have not yet done so. Any advice / trouble shooting would be appreciated.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | maybe you switched the wires in the exchange. Is it possible the turns and brakes are wired into the park light filament and you just can't see them when the headlights are on because the "park" lights are too bright? | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | You might check your ground wires. I had a problem like that, it turned out that I needed to run a separate ground wire for the tail lights to the frame. Solved the problem. Just a thought. George | | | | | Joined: May 2005 Posts: 39 'Bolter | | 'Bolter Joined: May 2005 Posts: 39 | After sleeping on it a little bit I was thinking it might be a ground issue myself. I painted the mounting brackets before I installed the new taillights on them. Like I said, everything works fine, until I turn the headlights on. After that it all goes downhill. I'll let you know how it works out. | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Did your truck come from the factory wity turn signals?
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: May 2005 Posts: 39 'Bolter | | 'Bolter Joined: May 2005 Posts: 39 | Toyvo,
My truck had two different tail lights, one on each side the box, when I got it but it did not have turn signals until I converted the tail lights, so that they would also function as turn signals. I mounted a signalstat turn signal to the steering column and it worked for the past 5 years.
The only reason I replaced the existing tail lights was so I would have a matching pair.
| | | | | Joined: May 2005 Posts: 39 'Bolter | | 'Bolter Joined: May 2005 Posts: 39 | Problem solved!! I crossed a wire when installing the new lights. Thanks for the help and tips. | | |
