1 members (texczech),
51
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | I noticed I can remove the ignition key while the engine is running on my 57 (6 cyl) Is this normal or is my lock or key worn allowing this?
Thanks, | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | normal on an original lock - you may also find you can turn it on with a screwdriver if it's worn  Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Your '57 probably has an "off" position where you could take the key with you and the farm hands could start the truck without the key. It's the first position after you take it out of "lock". | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Your '57 probably has an "off" position where you could take the key with you and the farm hands could start the truck without the key. It's the first position after you take it out of "lock". | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Isn't there something like a "thumb/finger" bar, so you can turn the cylinder? Also you can turn it off & on without the key? Back in the day when you could trust your vehicle wouldn't get stolen. Or maybe they didn't want to make a lot of keys for the company truck? Just thinking out loud. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yeah, that's what I'm talking about. In the earlier AD trucks there was a little tab as you describe. On my '56 its a raised grab area around the key. I'm assuming the '57 is the same. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | this is what yer talkin of [tho' it's not exactly like originals] - I think that style was on the cars, the trucks originally had the plain face locks, at least in my experience Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My 55.1 panel had the second one. It was worn to the point I used a church key to turn it off & on.
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I had a 55.2 years ago that was so worn that I could turn it on by putting my thumb on the face of the switch and turning it. After I figurered that out, I don't think I ever used the key to turn it on. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Obviously from a time when you didn't have a steering lock!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Both cars and trucks of that era had the rib that you could turn them on/off without a key, however, if you turned them past vertical to the most counterclockwise position and then removed the key they were locked and a key was required to turn them back on.
Evan
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I have a NOS 54-55.1 ignition switch. The switch has three positions, and in each position the key can be removed. But, in none of the positions can the switch be opperated without the key.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | my 52 did that, in fact some times the key would just fall out while driving it........lol Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I just checked my NOS 54 switch with a meter to see how it works.
All the way counter clock wise is off, the key can be removed.
Center position is on or run. The key can be romoved. From the center position the switch can be turned off with a screw driver by turning it clock wise.
All the way clock wise is the off position for the "screw driver key" method. The key can be inserted and turned to the center position. This is the ranch hand option that others have mentioned.
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | My '56 has the original switch. It has 2 positions, off and on. there is no accessory position. It is smooth across the face like the 2nd one in Bill's (Red58) pictures.
best wishes,
Les | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | My 54 3100 with the original switch is also like the one in Bill's second picture, with only an On and Off position. Samantha
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I've only ever seen the 2 position ones on the 6 cyl foot start trucks, I'd be willing to bet all the originals had only on/off positions, no 'acc' or'lock', that started with the V8's and solenoid starters, which is the switch that's available repro
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You're right Bill. One of the wiring diagrams I've seen shows a schematic for both switches. And you're right about the V8 one being the only repop. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Here is a shot of my NOS switch.I have owned many 3 ADs and more TFs than I can remeber and they have all been original 6 cylinder trucks. I have never run across the 3 position switch before. So this one is new to me, with the 2 offs and one on position. This switch does not have an accessory position. Hey Denny, sorry to here about your "NOS" fan. This switch is how all NOS parts should look. I picked this up from Tom Meyer in Oklahoma. Great guy, I got several hard to find parts for my 54 hydro truck, from him. | | | | | Joined: Aug 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 37 | Wearing out the cylinder locks from having a heavy key ring hanging from them is still common today. I just replaced the switch in my '91 S-10 after driving it for 4 years with no key. The old one wore out 3 keys before the lock wore out. If it bothers you not needing a key, put in an after market switch. I just always made sure my doors were locked. | | |
