3 members (RLB, Oswald, GRNHydra), 86 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#566078 08/17/2009 10:02 PM
Riding in the Passing Lane
Can someone tell me which term. on the temp gauge the hot wire goes to. It's a second series 55. If it is hooked up wrong will it fry thr gauge.
1972 Chevy c10 Cheyenne Super
hot being the one that goes to the ign sw [power], I believe it hooks to the drivers side term - the one to the sender is ground, toward pass side - if the gauge is known good and you hook it backwards, you can tell as soon as you turn on the key, instead of jumping up to C it'll either bury itself to the left or jump to H, you'll know to turn off the key grin I doubt that would fry it
Flxible #566117 08/18/2009 12:12 AM
Aren't dual terminal temperature senders for idiot lights?
LG
I don't own a vehicle that isn't old enough to drink.
LGriffin #566124 08/18/2009 12:31 AM
gauge Grif, not sender wink
Flxible #566209 08/18/2009 4:18 AM
Umm, '55 2nds have mechanical temp gauges. '56 is electric. wave
Bill Burmeister
LONGBOX55 #566213 08/18/2009 4:25 AM
not always, may depend on truck size/model, I've got a gauge set from a 55 5T that has the elec gauge .... and we can only answer questions as asked wink
Flxible #566230 08/18/2009 5:32 AM
OOoops, my bad. I should have known it was pass my nap time.
LG
LGriffin #566289 08/18/2009 2:53 PM
Just going through that with my '64. From what I've read, it seems that you won't fry it if it's backwards. I believe it is like a light bulb, as long as power goes through it, it don't matter which way. I tested mine to see if it works (it was out of the truck) by putting wires on it and just touching them on a battery. The needle would jump to H hooked up either way but what I DID notice is that wired one way, the needle would hang on H for a few seconds after I removed the ground wire as if there were some sort of residual power and wired the other way, it would immediately go back to C. I made a note of which was which and will wire it so as the needle returns to C right away.
Thanks for the help everyone. George
Flxible #566453 08/19/2009 1:53 AM
Just givin' ya a hard time red grin. The manuals (shop and assembly) only show the mechanical, but I wouldn't be suprized at all if they didn't to a running change. Mine did have the mechaical gauge, but i swapped it out to an electric gauge from a '56.
Bill Burmeister
LONGBOX55 #566774 08/20/2009 12:12 AM
Update. Just tried mine. Took the truck for a drive and the gauge didn't move. Got home, reversed the wires and the gauge now goes to Hot. I may have the wrong sender but it appears that the wires do have to be the right way.
