| | | Forums66 Topics128,056 Posts1,055,798 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56624 02/16/2006 7:15 PM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | I bought mounts from one of our popular board vendors and they were made in India. I tried for a couple hours to get them lined up, and my son came home and together, we got three, but the fourth is about 1/8" off. We had a hoist, and tried everthting we could think of from a sling to pry bars. I got a busted lip and chipped tooth out of the deal. We loosened the three hoping that would give us play. Any other ideas how to get in? | | |
#56625 02/16/2006 8:11 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | bob, I have seen so many with enlarged mount holes I think they almost came that way. I have loosened all the bolts on the stands also to get things lined up. I have also found offshore mounts with differents threads, one guy bought two mounts for his 283, one was 3/8 the other mount was threaded 7/16. brian | | |
#56626 02/17/2006 10:42 PM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Thanks, We're going to loosen some of the mount bolts this weekend and give that a try. I saw in the assembly manual that the front ones had one slot built into the bracket on some of the early 60's ones.Hmmm...wonder why they did that? How goes the burb? | | |
#56627 02/17/2006 10:51 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I always blast that hole in the bracket about twice its normal size. Than use the thick flat washer under the hole. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#56628 02/18/2006 12:03 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Oh, believe me, I was ready to blast it the other night....but the blasting was going to occur with 10" long cylindrical sticks with a fuse sticking out the end!! It is the one at the back that I'm having trouble with, and I can see most of the threads from the hole in the bottom......all but about 1\8" worth of them! | | |
#56629 02/18/2006 12:25 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | the burb is moving along slowly, I have the seats at an old school upholstery guy me & my bro found locally. I just about have old black truck stripped, it is down to (almost)bare cab & frame, just an e-brake cable, a brake hose or two left to remove before the last of it goes to China. brian | | |
#56630 02/18/2006 4:11 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Wow! That doesn't sound slow to me. That's about two years worth for me!! Will the old school guy be putting it back to a stock look? | | |
#56631 02/18/2006 4:21 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | yeah, he is even putting the white stripe in the backrest, the OE nylon material will be replaced w/a kind of tweed. Fella works by himself in a small shop behind his house. Seems most of the pro upholstery shops around here have folded. brian | | |
#56632 02/18/2006 7:49 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Hey-on those mounts,could yyou be fighting the old 250/292 mount difference? When I bought my 66 C-60,it was without engine and radiator.I was told by the owner it had a 292 in it. I bought a 292 and had big problems getting the right mount to line up. Turns out,the previous owner didn't know a 250 from a 292,and the truck was actually built with a 250. I was finally able to fit it together by hogging out the center hole on the right side frame bracket and using the big flatwasher,like Wrenchbender does. I could have ground off the rivets and moved the frame bracket,re-drilled the frame,and bolted it down,but the engine was already in and mostly done,so I chose the path of least intensive labor. Speed | | |
#56633 02/19/2006 3:46 PM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | It is the original 250 that came out of the truck. I am certain it is not a 292.
Thanks | | |
