6 members (Samantha, Guitplayer, lumbersawyer, 2-Ton, Lightholder's Dad, Otto Skorzeny), 91 guests, and 2 robots.
Topics128,154
Posts1,056,853
Members48,456
dose any body know who makes the most durable shroud and fan i need it to be a pusher iam running stock rad in my truck from a ton &1/2 its a 3 or 4 core it runs 190 on highway runs about 210 idling have not let set runnig to see thust ho high it will go thanks ball48pu photobucket.com-ball48pu
Jim & Caroline
nice clean looking truck u got there u spent a lot of time with it , i only 2inches between radiator and water pump can not put fan blade on it i only have 7inches from center of pump to lower rad hose have thought of biulding shrod for the front of radiator but i think i will have to punch lovers in bottom of shrod for highway air flow thanks photobucket.com-ball48pu
