7 members (JW51, Uncles51, Jaison, Wayne67vert, Johnny Rib, Robert Crandall, 1 invisible), 70 guests, and 1 robot.
Topics128,041
Posts1,055,481
Members48,424
#565805 08/17/2009 1:27 AM
My 53 3100 seat riser has some rust-out. I've checked multiple sources and done the stovebolt search. Anyone know where I can buy the riser without the entire floor?
Dan B. #565815 08/17/2009 1:59 AM
Post a want ad in the Swap Meet?
I'll look tomorrow but I think the riser is attached with spot welds. Is the floor under your seat riser sound?
tclederman #565823 08/17/2009 2:18 AM
I haven't seen this part as a separate replacement panel. (Maybe someone will prove me wrong)
If your floor is good you might be able to salvage a riser from a junkyard AD.
If you are careful with a spot weld drill I don't see why you couldn't remove one without butchering it.JMO
More pix on Flickr.
check with Jimbo59 on this site, or check with Tom Myers, tom's truck parts miami OK. Jimbo is just south of FT Worth
bluedot38 #565869 08/17/2009 3:49 AM
I replaced the drivers side floor. The riser looks simple enough to remove and replace but I'm really surprised I can't find the aftermarket parts.
Dan B. #565875 08/17/2009 3:59 AM
Don, I do not know right off hand where I saw it but one is available but not just the riser by itself. I think it was part of the floor board.... this is from my bad memory!!
EDIT: check out "sheet metal" on several of the vendors. I know I saw it somewhere.
Achipmunk #565886 08/17/2009 4:20 AM
Yes, it is available as part of the entire cab floor assembly. Just can't justify $529 when I don't need it all.
Dan B. #565887 08/17/2009 4:22 AM
..... I understand perfectly! And thats probably what I saw.Sorry.
Achipmunk #566197 08/18/2009 3:43 AM
Have you thought about cutting out the bad metal and welding in some new? I found some 1" 16 gauge angle at Lowe's that looks like it will weld in the bad areas pretty well. A Dremmel tool and there small grinding disk will get in most areas to make the cuts.
neilroy #566430 08/19/2009 12:46 AM
Apprentice
Apprentice
Hey guys, I think I removed the seat riser from my 48 AD then decided to replace the entire floor. I will look in my shop tomorrow and let you know for sure.
Thanks for the ideas. In fact,I buy sheet metal panels at Lowe's and use them for patches. I'll search a little more for the 16 gauge angle. My wife thinks Lowe's is "the other woman" I spend so much time there.
Dan B. #567115 08/21/2009 12:38 AM
Apprentice
Apprentice
I have a seat riser from my 48. I took it out and then decided to replace the floor....Let me know if you want it. Thanks, Don
Don:
Thanks for the offer but I was able to find a piece of angle I can weld in. As it turns out, I really only need to replace about a foot long section.
Dan
