| | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56576 02/15/2006 10:47 PM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | So heres the deal. I pulled the dipstick in my 235 (1961) today and the oil is watery with white in it. From my experience this means that I am in need of a new head gasket. I had the oil changed 2 weeks ago. This worries me a bit, but I think that I caught it in time to fix it before really bad things happen.
Now, here's the qestion. How hard is it to swap a head gasket on this motor. Seems to me like it should be pretty easy to do. Pull the valve cover, take off the rockers, pull the push rods, take off the head, and there I am? I am going to exchange the head at the local machine shop for a rebuilt one, is this OK? Should I have my head rebuilt and reuse it? I am also going to buy new pushrods and rockers since I will be in there anyway. Is there any other things I should do while I have the head off?
Any thoughts and comments will be greatly appreciated. I have never done a head gasket before but there is a first time for everything and this seems like a good time to learn.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
#56577 02/15/2006 11:02 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Fort Knox,
If you have a head gasket leaking into the crankcase (oil), and you have run the engine for any length of time, the oil will be creamy white like a vanilla milkshake.
Watery, meaning not viscous, might be misleading. Streaks of white, or globs of white can happen from little use, or not getting the rig up to full temperature.
A head gasket failure between water jacket and pan isn't usually the case. A blow between cylinders is much more common, and this might intrude into the water jacket.
The conditions that would only involve the cooling system and a path to the pan, I think, would be rare.
It sounds like you "want" to do this task come hell or highwater..go for it!
If you don't want to do it..test further. A conventional "blown" head gasket will show itself in a whole bunch of obvious ways.
Stuart | | |
#56578 02/15/2006 11:06 PM | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I would do a dry/wet compression test first and fully diagnose the problem.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
#56579 02/15/2006 11:18 PM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | what is dry wet compression test??
#56580 02/15/2006 11:18 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Do you get any white smoke out the exhaust? Pull the plugs & check for any coolant on them or in the cylinder. You have the procedure pretty down pat but you will want to pull the manifolds too. If you leave the exhaust pipe hooked up they will set aside. You will probably want to keep the same head & have a machine shop do a valve job & check for cracks & surface grind it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#56581 02/16/2006 12:09 AM | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Knox; 1. Pull all your plugs 2. Starting with No.1 or No 6 Cylinder screw in the compression gauge and take a dry reading from each of the cylinders 3. Make sure you write down the readings 4. Repeat the process, only this time, squirt a small amount of oil into each cylinder before you crank the engine. Approx. a teaspoon full 5. Compare your readings. - the dry readings should be lower than the wet readings, if not this could indicate bad rings - two cylinder next to each other indicate the head gasket is blown between the two cylinders - My 48-51 sop manual says compression should be about 110 Lbs. with all cylinders within 5-10 punds of each other
#56582 02/16/2006 12:40 AM | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | Another quick test is take the radiator cap off (engine cold) and fill it to the top. Start the engine and let it run for a while.If the gasket is leaking, you might be able to see air bubbles come up. | | |
#56583 02/16/2006 12:53 AM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | I am going to go out and check the plugs. I filled the radiator this morning so I will cheack the level to see if it is down. I called a machine shop and they told me that it would cost $250 to rebuild the head, new seats, valve job, surface grind. Is that reasonable? Thanks for the tips, I will do my best to try them all!
#56584 02/16/2006 1:32 AM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | your white or wet water in pan or on dipstick depending on how much is almost normal. Like someone said if it is driven cold alot... what it is is condensation buildup. That happens alot on older engines that dont have pcv valves...... if its not mixed into the oil...hence like someone else said like a milkshake,,,i wouldnt worry about it too much... the thing ya can do is check the breather on the valve cover...and also the downdraft tube to see if its not restricted...
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#56585 02/16/2006 2:10 AM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | ALL IS WELL!!!! I have decided that I was being a little bit overzealous. The oil is clean and black. I pulled the drain plug, no creamy stuff or anti-freeze. I pulled all of the plugs and none of them were dirty or coolant covered. I checked and re-checked the oil, clean and black. My anti-freeze levels have not dropped since this morning. With the cap off there are no bubbles coming up when engine is running. I think that all is well and I was overly concerned. Thanks for all of the advice, I really appreciate it. This page is a Godsend.
#56586 02/16/2006 4:54 PM | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | For future reference Knox, $250 is a good price | | |
#56587 02/17/2006 4:03 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | if you are concerned about coolant in the oil inject shop air into each cyl and watch radiator for bubbles be sure to fill full of coolant to top of neck each cyl will have to be at tdc or engine will spin...doc | | |
#56588 02/17/2006 4:14 PM | Joined: Aug 2004 Posts: 47 Member | | Member Joined: Aug 2004 Posts: 47 | I had this problem in my '57. The draft tube was in place, but the oil fill cap was not vented. So even though the engine could get to operating temps, the engine could not breathe. I replaced the fill cap and have not seen the build-up since. | | |
