2 members (68ironhead, stlcardinalsguy), 187 guests, and 14 robots.
Topics128,078
Posts1,056,036
Members48,433
#56534 02/14/2006 6:54 PM
I have managed to remove my king pin that was not getting grease thru one zerk. It is rusty at one end. I will replace it. Where does on get the stainless ones mentioned? Also, in taking mine apart I saw the caps, but no retaining rings. Should I have these rings? I see no groove for them. Thanks - Scott
P.S. 8lb. sledge about 250 hits.
55 1st Chev.
scdascda,
How well did the Tech Tip help you in your king pin adventure?
What info was lacking that might have helped!
Stuart
It did help. I managed to persuade it with an 8lb. sledge without taking the fender off. I figured I couldn't accurately swing it that far and guarantee that I didn't hit something wrong anyway. I started by crawling under the fender to swing it, but I could not control the left right of the swing, but I could control the forward back of the swing. And, left right would get me into the king pin opening and wreck it. So, I got out from under there and did it from the position I would use to remove a wheel. Then the left right made no difference. I could swing it about 30 times before I got out of breath. Moved inperceptably for first 100 blows, but quicker and quicker after that. I figure about 300 blows. Appreciated the tips very much. Scott
55 1st Chev.
Here's the link to Stainless Steel Brake tech tip and the address stuff.
http://www.classictrucksweb.com/tech/0101ct_kingpin/
Stainless Steel Brakes Corporation
11470 Main Rd., Dept. CT
Clarence, NY 14031
(800) 448-7722
www.ssbrakes.com
