| | | Forums66 Topics128,078 Posts1,056,057 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56534 02/14/2006 6:54 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I have managed to remove my king pin that was not getting grease thru one zerk. It is rusty at one end. I will replace it. Where does on get the stainless ones mentioned? Also, in taking mine apart I saw the caps, but no retaining rings. Should I have these rings? I see no groove for them. Thanks - Scott P.S. 8lb. sledge about 250 hits.
55 1st Chev.
#56535 02/14/2006 7:35 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | scdascda,
How well did the Tech Tip help you in your king pin adventure?
What info was lacking that might have helped!
Stuart | | |
#56536 02/15/2006 6:55 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | It did help. I managed to persuade it with an 8lb. sledge without taking the fender off. I figured I couldn't accurately swing it that far and guarantee that I didn't hit something wrong anyway. I started by crawling under the fender to swing it, but I could not control the left right of the swing, but I could control the forward back of the swing. And, left right would get me into the king pin opening and wreck it. So, I got out from under there and did it from the position I would use to remove a wheel. Then the left right made no difference. I could swing it about 30 times before I got out of breath. Moved inperceptably for first 100 blows, but quicker and quicker after that. I figure about 300 blows. Appreciated the tips very much. Scott
55 1st Chev.
