2 members (BC59, Barry Martak),
64
Mod | | | Forums66 Topics128,179 Posts1,057,157 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 25 Apprentice | | Apprentice Joined: Jun 2009 Posts: 25 | Just received a few items for my 52 chevy. But don't know the right way to install it.
1st. Just received the rear fender bolts kit (Clutch head). The kit is coming with flat washers and locknuts. Just want to make sure on which side should I put the flat washer. On the bed side or on the fender side. I don't how was the original look (was trying to find pics but couldn't find any)
2nd. Just bought the front licence plate holder. (was not coming with mounting hardware and cannot find anything on catalogue. Wehre is the proper way to mount it.
As always, thanks for your advice.
Peioa
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | It's a good idea to look at the gallery there are alot of pic's of other trucks there , also get a factory assembly manual it will help thru out the build for all those little things that can drive You crazy I have not built My box yet ,My truck came in all taken apart , there is a tech tips section that has help on building the bed and You will get ALOT of help here too.
Pete | | | | | Joined: Jun 2009 Posts: 25 Apprentice | | Apprentice Joined: Jun 2009 Posts: 25 | I already looked at both of those resources but couldn't find any information or picture.
Thanks for the advice. Peioa | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Peioa...The washers go to the fender side. Only the bolt heads are visible inside the bed.
The licence plate holder goes on the RH side of the splash apron. Mine had two captive nuts welded below the apron. As far as I know, they were factory.... I would double check for you but mine went out with the trash! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jun 2009 Posts: 25 Apprentice | | Apprentice Joined: Jun 2009 Posts: 25 | By the way, was there any stock Apron in the back bumper (like the one in the front bumper)?
Let me know. Peioa | | | | | Joined: Jun 2009 Posts: 25 Apprentice | | Apprentice Joined: Jun 2009 Posts: 25 | One last question (for the moment...) I have a small block chevy 350 in my 52 chevy and would like to put new headers. Now by just looking at it, I know I'm going to have some clearance issues. The steering column is a couple inches away from the headers and the firewall is really close too.
I'm sure I saw a post on that subject but I can't find it anymore. Does anybody know which headers will clear my steering column and my firewall (both stock) ?
Thanks for your time and infos. Peioa | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Peioa....There are quite a few 'variables' as the 52 obviously didn't come from the factory with the V8..... Have you got any pics? I'm having 'clearance issues' with mine just now,but that could be due to a lack of foresite on my behalf. I'm just working with what came with my engine. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | There are several types of headers available.First thing ya gotta do is to do the measuring,then go to a good speed shop,and see what headers they have in stock. On a 1937 Chevy car that I streetrodded,with a 350.I used the S_10 conversion headers which worked out quite well.They exit to the rear. Then on my 55 pickup with a 350 I used a nice set of blockhugger headers which exit straight down.Anytime you put a later model engine in one of these older vehicles,you are gonna have clearance problems,but with the headers available today there is always an easy solution. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The header question needs to be posted in the HIPO forum. | | |
